SDI12 Library with NANOESP32
Home › Forums › Other Data Loggers › SDI12 Library with NANOESP32
Viewing 0 reply threads
    • #19164
      LMU
        I want to use the ARDUINO NANOESP32 with the adapter from IRROMETER. (https://www.irrometer.com/pdf/426.pdf).
        Even the simple “0I!”command doesn’t produce any output on the serial monitor. The same sketch with a MEGA 2560 works. Are there any limitations regarding the use of the pins or with the NANOESP32 in general?
