Solar Panel covered with sap-like material
Home › Forums › Mayfly Data Logger › Solar Panel covered with sap-like material
    • #19896
      DG
        Punches Run MSPR2S solar panel (one of the newer types of solar panel) appears to be covered with a sap-like material presumably from nearby trees.  It is affected function.  What type of solution can be used safely on the panel in order to remove the material. Simple soap and water is not effective.
      • #19897
          I’d suggest trying a product called Goo Gone.  It’s a citrus-based adhesive/sap remover that is safe for use on plastic.  DO NOT use Goof Off, it isn’t safe for plastics and will damage the solar panel.  Rub a little Goo Gone on the sap and let it sit for a few minutes, then wipe it off and rinse it off with some soap and water.  It might take a couple tries, but it should take care of it.
