Library issues
Home › Forums › Mayfly Data Logger › Library issues
    • #19756
      jsterling
        I’m working on building a sensor station using a Mayfly Data Logger v. 1.1, EnviroDIY cellular bee, a Hydros 21 CTD sensor. I am using the sketch EnviroDIY_Monitoring_Kit.ino and the Modular Sensor Libraries v0.37.0. I am having a difficult time getting my sketch to compile.  I am receiving the following error that it cant find MonitorMyWatershedPublisher.h. Am I using the correct libraries for this sketch? I’ve attached a photo of my error. Thanks!
        fatal error: publishers/MonitorMyWatershedPublisher.h: No such file or directory
        #include <publishers/MonitorMyWatershedPublisher.h>
        compilation terminated.
        exit status 1
      • #19758
        jsterling
        • #19765
            Ah. That example is written for the current “master” branch of the library, not the latest polished release.  I’m way overdue for a new release, but there are some bugs I still need to fix.
            Try starting from this example instead, which is matched to library release 0.37.0:  https://github.com/EnviroDIY/ModularSensors/blob/v0.37.0/examples/DRWI_Mayfly1/DRWI_Mayfly1.ino
            **DO NOT** use the current master branch as of 8/4/2026. There’s definitely a bug in for the SIM7080/EnviroDIY LTE module.  Usually I keep the master branch functional and try to keep not-actually-working stuff in other branches, but as of today master is broken.
