Mayfly unit stop sending data to the online site
Home › Forums › Monitor My Watershed › Mayfly unit stop sending data to the online site
    • #19877
      TUBearRiver
        My Mayfly unit stop sending data to the online site on Sept 17, 2025. I just pulled the unit and brought it home and was able to pull data from the memory card for 8/12/2022 to 1/3/23 and 5/12/2023 to 1-21-26.
        Nothing after 1-21-26 shows up and it is important to have this data due to it being the worst drought year on record. I have the mayfly at home now and need to re link whatever broke so that it is uploading to the cloud for me. Please let me know my options
        https://monitormywatershed.<wbr />org/sites/NorthEden_01/
      • #19884
          For data you have on the SD card, you can upload it so that it appears online following these instructions: https://wikiwatershed.org/wp-content/uploads/monitor-my-watershed-quick-guide-uploading-data.pdf.  NOTE: The instructions mention that there’s a file size limitation.  That limitation no longer exists.
          Sadly, though, if your data isn’t on the SD card and wasn’t posted online, there is no way to recover it. There is no other place the data would be stored.  The SD card is the only local data storage on the Mayfly.  If something happened that made the whole station go down and stop writing to the SD card, there’s nowhere to recover any data from.
          For me to help fix the station so it will record and publish data again, I’ll need to know more about its current condition.  Are you sure the battery is good? Have you tried turning the station back on to watch what it does on your desktop? Do the lights blink when you turn it on? Which lights? Can you connect it to a computer and share the serial monitor output?
