Parts list, European vendors – Water level and ph
Home › Forums › Mayfly Data Logger › Parts list, European vendors – Water level and ph
    • #19752
      Jasper
        Hi EnviroDIY community. We’re looking to set up 1-2 EnviroDIY stations in Ireland.
        We’re currently looking at multiple potential use cases. Water level monitoring for a kayak club and water level + ph monitoring for two environmental groups.
        I’ve looked into sensor options and sourcing of the parts list in Ireland. Could someone please check that the below parts list is complete? I have included the vendors in case others are interested. Here’s a google sheet with the details like prices and exact vendor links.
        We’d like to start with sensors that have been proven to work well and are lower cost than the Hydros 21. From what I’ve read here that means the MaxBotix MB7389 and Atlas Scientific ph kit should be a good start. Can someone please confirm.
        • Is the MaxBotix MB7389 the proven choice for more affordable ultrasonic out of the water measurement vs using the Hydros? I’m aware that the range is 30cm to 5m and we should avoid noisy environments. That as per this post free standing mounting seems better than a standpipe. And that as per this post mounting the sensor directly to the Pelican case is an option.
        • Is the Atlas Scientific ph kit the proven choice for ph measurements? I’m aware that we’ll have to clean the probe every few weeks.
        Part List
        EnviroDIY Mayfly. Approx. 415 Euro, incl. 23% Irish VAT.
        • EnviroDIY Mayfly Data Logger Starter Kit & EnviroDIY LTE Bee. [Available from the UK via Labcrafter since June. Yay!]
        • CR1220 12mm D3V coin battery. [RS online, Ireland.]
        • 3.7V 4400mAh battery pack. [Kiwi electronics, Netherlands. Or 5200mAH from RS online, Ireland.]
        • Pulse Electronics LTE antenna. [Digi-Key, US.]
        • 1NCE Global Sim Card. [1NCE, Germany. The only European option I found that doesn’t state “contact sales”.]
        • Voltaic Systems 5W Solar Panel. [Kiwi electronics, Netherlands. Or Digi-Key, US.]
        • Voltaic Systems solar panel extension cable. [Kiwi electronics, Netherlands.]
        • Voltaic Systems JST 2-pin cable. [Kiwi electronics, Netherlands.]
        • Voltatic Systems solar panel bracket. [Kiwi electronics, Netherlands.]
        • Phoenix Contact PTSM 0.5/2-P-2.5. [RS online, Ireland.]
        • Optional: Grove 4Pin cables 5 pack. [RS online, Ireland. Kiwi electronics, Netherlands.]
        If I take a different LTE antenna or find an alternative source I can source the core Mayfly setup without Digi-Key and thus completely from Europe. However, Digi-Key shipping is free when getting the MaxBotix from Digi-Key.</span>
        Conductivity, Water Level (pressure), Temperature Water – Hydros 21. Approx. 872 Euro, incl. 23% Irish VAT.
        • Hydros 21 sensor. [METER Group, Germany.]
        • Seeed Grove screw-terminal breakout. [RS online, Ireland.]
        Water Level (ultrasonic) – MaxBotix MB7389. Approx. 123 Euro, incl. 23% Irish VAT.
        • MaxBotix MB7389-100. [ EXP Tech, Germany. Digi-Key, US – free shipping.]
        • Cut and solder a Grove 4Pin cable when mounting directly to the Pelican case or buy a shielded cable in person.
        pH – Atlas Scientific KIT-101P. Approx. 220 Euro, incl. 23% Irish VAT.
        • Atlas Scientific ph KIT-101P. [Sensors & Probes, Netherlands.]
        • Cut and solder a Grove 4Pin cable.
      • #19759
          We’re really excited to partner with Labcrafter so they can be a source of our products to people in Europe.  As for sensors, the Maxbotix MB7389 you mentioned is probably your best bet for low cost ultrasonic rangefinding.  Just be sure to order the TTL version so it’ll work straight into the Mayfly board (the RS232 sensor would require an interface chip).  I haven’t used the Atlas Scientific pH sensors so I don’t have any advice on them.
