battery size options
Home › Forums › Monitor My Watershed › battery size options
Viewing 0 reply threads
    • #19773
      nick
        Sorry, I posted this in the wrong forum; I relocated this post to the Mayfly data logger forum. Are there any negatives in choosing the 10050 mAh battery https://www.adafruit.com/product/5035? Size wise it is the same as the 6600mAh that you have listed on your site https://www.envirodiy.org/battery-options-mayfly/. I’m thinking the higher mAh would maintain the voltage better. Or does the long recharge time put a hinderance on things. I’m assuming it is ok to use since it is 3.7v, but since it wasn’t listed on your site, I just wanted to double check.
    • The topic ‘battery size options’ is closed to new replies.
